远程获取类Asp xmlHttp
2013年11月28日 11:39 本文热度 6730
这个class主要用于操作asp中的xmlhttp。
首先是类定义 Cls_AspHttp.asp:
''飞扬远程获取类(AspHttp) 1.0.1 Bate1
'' By 奔腾的心
'' 2006-04-19
Class FlyCms_AspHttp
Public oForm,oXml,Ados
Public strHeaders
Public sMethod
Public sUrl
Public sReferer
Public sSetCookie
Public sLanguage
Public sCONTENT
Public sAgent
Public sEncoding
Public sAccept
Public sData
Public sCodeBase
Private slresolveTimeout,slconnectTimeout,slsendTimeout,slreceiveTimeout
'' 类模块初始化
Private Sub Class_Initialize()
oForm = ""
Set oXml = Server.CreateObject("MSXML2.ServerXMLHTTP")
set Ados = Server.CreateObject("Adodb.Stream")
slresolveTimeout = 20000 '' 解析DNS名字的超时时间,20秒
slconnectTimeout = 20000 '' 建立Winsock连接的超时时间,20秒
slsendTimeout = 30000 '' 发送数据的超时时间,30秒
slreceiveTimeout = 30000 '' 接收response的超时时间,30秒
End Sub
'' 返回版本信息
Public Property Get Version
Version = "飞扬asphttp类1.0.0"
End Property
'' 解析DNS名字的超时时间
Public Property Let lresolveTimeout(LngSize)
If IsNumeric(LngSize) Then
slresolveTimeout = Clng(LngSize)
End If
End Property
'' 建立Winsock连接的超时时间
Public Property Let lconnectTimeout(LngSize)
slconnectTimeout = Clng(LngSize)
End If
End Property
'' 发送数据的超时时间
Public Property Let lsendTimeout(LngSize)
slsendTimeout = Clng(LngSize)
End If
End Property
'' 接收response的超时时间
Public Property Let lreceiveTimeout(LngSize)
slreceiveTimeout = Clng(LngSize)
End If
End Property
'' Method
Public Property Let Method(strMethod)
sMethod = strMethod
End Property
'' 发送url
Public Property Let Url(strUrl)
sUrl = strUrl
End Property
'' Data
Public Property Let Data(strData)
sData = strData
End Property
'' Referer
Public Property Let Referer(strReferer)
sReferer = strReferer
End Property
'' SetCookie
Public Property Let SetCookie(strCookie)
sSetCookie = strCookie
End Property
'' Language
Public Property Let Language(strLanguage)
sLanguage = strLanguage
End Property
'' CONTENT-Type
Public Property Let CONTENT(strCONTENT)
sCONTENT = strCONTENT
End Property
'' User-Agent
Public Property Let Agent(strAgent)
sAgent = strAgent
End Property
'' Accept-Encoding
Public Property Let Encoding(strEncoding)
sEncoding = strEncoding
End Property
'' Accept
Public Property Let Accept(strAccept)
sAccept = strAccept
End Property
'' CodeBase
Public Property Let CodeBase(strCodeBase)
sCodeBase = strCodeBase
End Property
'' 建立数据传送对向!
Public Function AddItem(Key, Value)
On Error Resume Next
Dim TempStr
If oForm = "" Then
oForm = Key + "=" + Server.URLEncode(Value)
Else
oForm = oForm + "&" + Key + "=" + Server.URLEncode(Value)
End If
End Function
'' 发送数据并取回远程数据
Public Function HttpGet()
Dim sReturn
With oXml
.setTimeouts slresolveTimeout,slconnectTimeout,slsendTimeout,slreceiveTimeout
.Open sMethod,sUrl,False
If sSetCookie<>"" Then
.setRequestHeader "Cookie", sSetCookie ''设定Cookie
End If
If sReferer<>"" Then
.setRequestHeader "Referer", sReferer ''设定页面来源
Else
.setRequestHeader "Referer", sUrl
End If
If sLanguage<>"" Then
.setRequestHeader "Accept-Language", sLanguage ''设定语言
End If
.setRequestHeader "Content-Length",Len(sData) ''设定数据长度
If sCONTENT<>"" Then
.setRequestHeader "CONTENT-Type",sCONTENT ''设定接受数据类型
End If
If sAgent<>"" Then
.setRequestHeader "User-Agent", sAgent ''设定浏览器
End If
If sEncoding<>"" Then
.setRequestHeader "Accept-Encoding", sEncoding ''设定gzip压缩
End If
If sAccept<>"" Then
.setRequestHeader "Accept", sAccept ''文档类型
End If
.Send sData ''发送数据
While .readyState <> 4
.waitForResponse 1000
Wend
strHeaders = .getAllResponseHeaders()
If sCodeBase<>"" Then
sReturn = bytes2BSTR(.responseBody)
Else
sReturn = .responseBody
End If
End With
HttpGet = sReturn
End Function
'' 处理二进制数据
Private Function bytes2BSTR(vIn)
strReturn = ""
For i = 1 To LenB(vIn)
ThisCharCode = AscB(MidB(vIn,i,1))
If ThisCharCode < &H80 Then
strReturn = strReturn & Chr(ThisCharCode)
Else
NextCharCode = AscB(MidB(vIn,i+1,1))
strReturn = strReturn & Chr(CLng(ThisCharCode) * &H100 + CInt(NextCharCode))
i = i + 1
End If
Next
bytes2BSTR = strReturn
End Function
'' 类模块注销
Private Sub Class_Terminate
oForm = ""
Set oXml = Nothing
Set Ados = Nothing
End Sub
End Class
function.asp 调用的代码: (简化了代码的书写)
''调试代码
Sub Re1(Str)
Response.Write Str
Response.End
End Sub
Sub Rw(Str)
Response.Write Str & vbCrLf
Response.Flush
End Sub
Function HttpGet(lresolveTimeout,lconnectTimeout,lsendTimeout,lreceiveTimeout,Method,Url,Referer,Data,SetCookie,Language,CONTENT,Agent,Encoding,Accept,CodeBase)
DoGet.lresolveTimeout = lresolveTimeout
DoGet.lconnectTimeout = lconnectTimeout
DoGet.lsendTimeout = lsendTimeout
DoGet.lreceiveTimeout = lreceiveTimeout
DoGet.Method = Method
DoGet.Url = Url
DoGet.Referer = Referer
DoGet.Data = Data
DoGet.SetCookie = SetCookie
DoGet.Language = Language
DoGet.CONTENT = CONTENT
DoGet.Agent = Agent
DoGet.Encoding = Encoding
DoGet.Accept = Accept
DoGet.CodeBase = CodeBase
HttpGet = DoGet.HttpGet()
End Function
'' 取得cookie头
Function GetCookie(ByVal strHead, ByVal sBound)
If strHead = "" Then
GetCookie = ""
Exit Function
End If
Dim strCookie, iCookie, bNum
strCookie = strHead
If strCookie <> "" And InStr(strCookie, "Set-Cookie") > 0 Then
strCookie = Replace(strCookie, "Set-Cookie: ", "〔")
strCookie = Replace(strCookie, ";", "〕")
Patrn = "〔[^〕]+〕"
strCookie = RegExpSearch(Patrn, strCookie, 0, "`")
strCookie = Replace(strCookie, "〔", "")
strCookie = Replace(strCookie, "〕", "")
strCookie = Split(strCookie, "`")
bNum = sBound
If bNum=-1 Then
For I=0 To UBound(strCookie)
If iCookie = "" Then
iCookie = strCookie(i)
Else
iCookie = iCookie & "; " & strCookie(i)
End If
Next
Else
If bNum > UBound(strCookie) Then
bNum = UBound(strCookie)
End If
iCookie = strCookie(bNum)
End If
End If
GetCookie = iCookie
End Function
'' 按照指定的正则表达式返回字符
Function RegExpSearch(Patrn, Str, sType, Spacer)
Dim RegEx, Match, Matches, RetStr, i
i = 0
Set RegEx = New RegExp
RegEx.Pattern = Patrn
RegEx.IgnoreCase = True
RegEx.Global = True
Set Matches = RegEx.Execute(Str)
For Each Match In Matches
i = i + 1
If sType = 0 Then
RetStr = RetStr & Match.Value
If i < Matches.Count Then RetStr = RetStr & Spacer
Else
If sType = i Then Exit For
End If
Next
RegExpSearch = RetStr
End Function
'' function(私有)
'' 作用 :利用流保存文件
Function SaveFiles(ByVal GetUrl, ByVal ToFile, ByVal sCookie, ByVal Agent, ByVal SaveShow)
Dim Datas, dSize
GetUrl = Replace(GetUrl, "\", "/")
Datas = HttpGet(10000, 10000, 20000, 20000, "GET", GetUrl, "", "", sCookie, "zh-cn", "", Agent, "", "*/*", "")
iSize = LenB(Datas)
dSize = FormatNumber(iSize / 1024, 3)
If iSize > 1 Then
Set Ados = Server.CreateObject("ADODB.Stream")
Ados.Type = 1
Ados.Mode = 3
Ados.Open
Ados.Write Datas
Ados.SaveToFile Server.MapPath(ToFile), 2
Ados.Close
Set Ados = Nothing
SaveFiles = True
If SaveShow = 1 Then
Response.Write "保存成功:<font color=red>" & dSize & "</font>Kb"
End If
Else
SaveFiles = False
Response.Write "保存失败:<font color=red>文件大小" & iSize & "K,小于1K</font>"
End If
End If
End Function
'' 检测文件夹是否存在 如果不存在就自动创建多级文件夹
Function CreatePath(strPath)
Dim fldr, FristStr
strPath = Replace(strPath, "\", "/")
strPath = Replace(strPath, Chr(0), "")
strPath = Replace(strPath, "//", "/")
If Left(strPath, 1) = "/" Then
FristStr = "/"
strPath = Right(strPath, Len(strPath) - 1)
Else
FristStr = ""
strPath = strPath
End If
If Right(strPath, 1) = "/" Then
strPath = Left(strPath, Len(strPath) - 1)
Else
strPath = strPath
End If
GetNewsFold = Split(strPath, "/")
fldr = ""
Set FSO = Server.CreateObject("Scripting.FileSystemObject")
For i = 0 To UBound(GetNewsFold)
If fldr = "" Then
fldr = FristStr & GetNewsFold(i)
Else
fldr = fldr & "\" & GetNewsFold(i)
End If
If FSO.FolderExists(Server.MapPath(fldr)) = False Then
Call FSO.CreateFolder(Server.MapPath(fldr))
End If
Next
Set FSO = Nothing
If Err.Number = 0 Then
Err.Clear
CreatePath = Replace(fldr, "\", "/") & "/"
Else
CreatePath = ""
End If
End Function
'' function(公有)
'' 作用 :保存文件,并自动创建多级文件夹
Function SaveData(FromUrl, ToFiles, sCookie, sAgent, SaveType, SaveShow)
Dim strFile, NewPath
strFile = Replace(ToFiles, "\", "/")
strFile = Replace(strFile, Chr(0), "")
strFile = Replace(strFile, "//", "/")
NewPath = Mid(strFile, 1, InStrRev(strFile, "/"))
If FSO.FileExists(Server.MapPath(strFile)) = False Then
If FSO.FolderExists(Server.MapPath(NewPath)) = False Then
Call CreatePath(NewPath)
End If
SaveData = SaveFiles(FromUrl, strFile, sCookie, sAgent ,SaveShow)
Else
'' 覆盖文件
If SaveType = 1 Then
Else
SaveData = True
End If
End If
Set FSO = Nothing
End Function
下面是一个使用的例子:
<!-- #include file = "Cls_AspHttp.asp" -->
<!-- #include file = "Function.asp" -->
Dim DoGet
Dim sCookie
Dim sUserAgent
Set DoGet = New FlyCms_AspHttp
Rw "下载91f的文件<br>"
Down91f
Rw "<br>下载haoting的文件<br>"
DownHaoting
Set DoGet = Nothing
Sub Down91f()
''91f 欺骗身份
sCookie = ""
sUserAgent = "NSPlayer/9.0.0.2991 WMFSDK/9.0 " ''这句模拟Media Player身份
FromUrl = "http://202.101.235.99/mu/MP/@2AC6BFD79E8BA1E58860618CDD2CEEB14//f/71/2.Wma"
ToFiles
该文章在 2013/11/28 11:39:44 编辑过
