C# 数据类型与PostgreSQL 数据类型映射
maoxiaoming
2025年8月7日 8:55
本文热度 905
Npgsql 是基于ADO.NET 的PostgreSQL 数据驱动。
Npgsql 官方 已经提供C# 数据类型与PostgreSQL数据类型的对应映射
地址: http://www.npgsql.org/doc/types.html
Type mappings
Type mappings when reading values sent from the backend
PostgreSQL type | Default .NET type | Provider-specific type | Other .NET types |
bool | bool |
int2 | short |
| byte, sbyte, int, long, float, double, decimal, string |
int4 | int |
| byte, short, long, float, double, decimal, string |
int8 | long |
| long, byte, short, int, float, double, decimal, string |
float4 | float |
| double |
float8 | double |
numeric | decimal |
| byte, short, int, long, float, double, string |
money | decimal |
text | string |
| char[] |
varchar | string |
| char[] |
bpchar | string |
| char[] |
citext | string |
| char[] |
json | string |
| char[] |
jsonb | string |
| char[] |
xml | string |
| char[] |
point | NpgsqlPoint |
| string |
lseg | NpgsqlLSeg |
| string |
path | NpgsqlPath |
polygon | NpgsqlPolygon |
line | NpgsqlLine |
| string |
circle | NpgsqlCircle |
| string |
box | NpgsqlBox |
| string |
bit(1) | bool |
| BitArray |
bit(n) | BitArray |
varbit | BitArray |
hstore | IDictionary<string, string> |
| string |
uuid | Guid |
| string |
cidr | NpgsqlInet |
| string |
inet | IPAddress | NpgsqlInet | string |
macaddr | PhysicalAddress |
| string |
tsquery | NpgsqlTsQuery |
tsvector | NpgsqlTsVector |
date | DateTime | NpgsqlDate |
interval | TimeSpan | NpgsqlTimeSpan |
timestamp | DateTime | NpgsqlDateTime |
timestamptz | DateTime | NpgsqlDateTime | DateTimeOffset |
time | TimeSpan |
timetz | DateTimeOffset |
| DateTimeOffset, DateTime, TimeSpan |
bytea | byte[] |
oid | uint |
xid | uint |
cid | uint |
oidvector | uint[] |
name | string |
| char[] |
(internal) char | char |
| byte, short, int, long |
geometry (PostGIS) | PostgisGeometry |
record | object[] |
composite types | T |
range subtypes | NpgsqlRange |
enum types | TEnum |
array types | Array (of child element type) |
转自
C# 数据类型与PostgreSQL 数据类型映射 - Pete-Jones - 博客园
该文章在 2025/8/7 8:55:49 编辑过
