C#实现文件上传和接收功能
2025年7月22日 18:6
本文热度 429
using System;
using System.IO;
using System.Web;
using System.Web.Http;
namespace Mes.Controllers
public class FileController : ApiController
[HttpPost]
public string UploadFile()
string result = string.Empty;
try
string fileName = HttpContext.Current.Request.Files[0].FileName;
Stream stream = HttpContext.Current.Request.Files[0].InputStream;
var forms = HttpContext.Current.Request.Form;
foreach (var item in forms)
string val = forms[item.ToString()];
string uploadFolder = "F:\\图片";
string savePath = System.IO.Path.Combine(uploadFolder, fileName);
FileStream fsWrite = new FileStream(savePath, FileMode.Create);
byte[] bytes = new byte[1024 * 4];
int total = 0;
int size = 0;
do
size = stream.Read(bytes, 0, bytes.Length);
fsWrite.Write(bytes, 0, size);
total += size;
while (size > 0);
fsWrite.Close();
result = "true";
catch (Exception ex)
result = ex.Message;
return result;
using System.Net;
using System.Net.Http;
using System.Net.Http.Headers;
public string PostFile(string url, Dictionary<string, object> dics, string filePath)
try
MultipartFormDataContent form = new MultipartFormDataContent();
using (HttpClient client = new HttpClient())
MediaTypeWithQualityHeaderValue temp = new MediaTypeWithQualityHeaderValue("application/json") { CharSet = "utf-8" };
client.DefaultRequestHeaders.Accept.Add(temp);
foreach (var keyValuePair in dics)
form.Add(new StringContent(keyValuePair.Value.ToString()), keyValuePair.Key);
Stream fileStream = new FileStream(filePath, FileMode.Open, FileAccess.Read);
var fileName = Path.GetFileName(filePath);
form.Add(new StreamContent(fileStream), "file", fileName);
Task<HttpResponseMessage> task = client.PostAsync(url, form);
task.Wait();
HttpResponseMessage response = task.Result;
response.EnsureSuccessStatusCode();
string responseBody = task.Result.Content.ReadAsStringAsync().Result;
Console.WriteLine(responseBody);
result = responseBody;
return result;
throw new Exception(ex.Message);
try
using (var fileStream = new FileStream(filePath, FileMode.Open, FileAccess.Read))
byte[] data = new byte[fileStream.Length];
fileStream.Read(data, 0, data.Length);
fileStream.Close();
form.Add(new ByteArrayContent(data), "file", fileName);
task.Wait();
return result;
该文章在 2025/7/23 12:17:41 编辑过
