C#通过添加System.Speech库引用实现Winform窗体报警语音播报
2025年6月23日 23:39
本文热度 926
我们在开发C#程序时,有时候会需要将报警信息通过语音进行播报,今天跟大家分享一下具体的实现过程。
首先我们创建好一个Windows窗体项目,然后添加System.Speech库引用。
点击引用,右击添加引用,在程序集中,找到System.Speech,这个库是Windows系统自带的,所以直接点击确定即可。
接下来我们对System.Speech这个库进行封装,核心围绕SpeechSynthesizer这个类。1、创建一个SpeechHelper类,初始化SpeechSynthesizer对象。 private SpeechSynthesizer synthesizer;
public int Rate;
public int Volume;
public SpeechHelper()
synthesizer = new SpeechSynthesizer();
synthesizer.SpeakStarted += Synthesizer_SpeakStarted;
synthesizer.SpeakCompleted += Synthesizer_SpeakCompleted;
synthesizer.Volume = 100;
synthesizer.Rate = 0;
public bool IsSpeeking { get; set; } = false;
private void Synthesizer_SpeakStarted(object sender, SpeakStartedEventArgs e)
IsSpeeking = true;
private void Synthesizer_SpeakCompleted(object sender, SpeakCompletedEventArgs e)
IsSpeeking = false;
3、开始播报和停止播报方法,这里建议使用异步SpeekAsync。public void Speak(string text)
if (!string.IsNullOrWhiteSpace(text))
synthesizer.SpeakAsync(text);
public void Stop()
synthesizer.SpeakAsyncCancelAll();
public void SetVolume(int volume)
if (volume >= 0 && volume <= 100)
synthesizer.Volume = volume;
Volume = volume;
public void SetRate(int rate)
if (rate >= -10 && rate <= 10)
synthesizer.Rate = rate;
Rate = rate;
public void SelectVoice(string voiceName)
try
synthesizer.SelectVoice(voiceName);
catch (Exception ex)
throw new Exception("无法选择语音 " + voiceName + ": " + ex.Message);
public string[] GetInstalledVoices()
List<string> list = new List<string>();
foreach (InstalledVoice installedVoice in synthesizer.GetInstalledVoices())
list.Add(installedVoice.VoiceInfo.Name);
return list.ToArray();
1、我们先创建一个简单的窗体:
2、核心代码就是创建SpeechHelper对象,调用Speek进行播报,调用Stop停止播报:
private SpeechHelper speechHelper = new SpeechHelper();
private void btn_Start_Click(object sender, EventArgs e)
if (!this.speechHelper.IsSpeeking)
this.speechHelper.Speak(this.txt_Content.Text);
private void btn_Stop_Click(object sender, EventArgs e)
this.speechHelper.Stop();
3、然后可以选择朗读者或者调节音量和语速:
private void FrmMain_Load(object sender, EventArgs e)
this.cmb_Voice.Items.AddRange(speechHelper.GetInstalledVoices());
private void cmb_Voice_SelectedIndexChanged(object sender, EventArgs e)
this.speechHelper.SelectVoice(this.cmb_Voice.Text);
private void track_Volumn_Scroll(object sender, EventArgs e)
this.speechHelper.SetVolume(this.track_Volumn.Value);
private void track_Rate_Scroll(object sender, EventArgs e)
this.speechHelper.SetRate(this.track_Rate.Value);
4、运行程序,结果如下所示:
选择朗读者,输入播报内容,点击开始播报即可。
该文章在 2025/6/24 10:47:21 编辑过
