ASP常用加密解密算法-Base64-OK
2010年5月8日 16:4 本文热度 8093
ASP常用加密解密算法-Base64
[code]
Base64加密算法模拟
sBASE_64_CHARACTERS = "Iz01BScostuDEKxT9WvM23LQh+/NeFGHklijUV678mnw4JApqrXOPdYZaRfgbCy5" '64个不重复的字符
sBASE_64_CHARACTERS = strUnicode2Ansi(sBASE_64_CHARACTERS)
Function strUnicodeLen(asContents)
'计算unicode字符串的Ansi编码的长度
asContents1="a"&asContents
len1=len(asContents1)
k=0
for i=1 to len1
asc1=asc(mid(asContents1,i,1))
if asc1<0 then asc1=65536+asc1
if asc1>255 then
k=k+2
k=k+1
end if
next
strUnicodeLen=k-1
End Function
Function strUnicode2Ansi(asContents)
'将Unicode编码的字符串,转换成Ansi编码的字符串
strUnicode2Ansi=""
len1=len(asContents)
for i=1 to len1
varchar=mid(asContents,i,1)
varasc=asc(varchar)
if varasc<0 then varasc=varasc+65536
if varasc>255 then
varHex=Hex(varasc)
varlow=left(varHex,2)
varhigh=right(varHex,2)
strUnicode2Ansi=strUnicode2Ansi & chrb("&H" & varlow ) & chrb("&H" & varhigh )
strUnicode2Ansi=strUnicode2Ansi & chrb(varasc)
end if
next
End function
Function strAnsi2Unicode(asContents)
'将Ansi编码的字符串,转换成Unicode编码的字符串
strAnsi2Unicode = ""
len1=lenb(asContents)
if len1=0 then exit function
for i=1 to len1
varchar=midb(asContents,i,1)
varasc=ascb(varchar)
if varasc > 127 then
strAnsi2Unicode = strAnsi2Unicode & chr(ascw(midb(asContents,i+1,1) & varchar))
i=i+1
strAnsi2Unicode = strAnsi2Unicode & chr(varasc)
end if
next
End function
Function Base64encode(asContents)
'将Ansi编码的字符串进行Base64编码
'asContents应当是ANSI编码的字符串(二进制的字符串也可以)
Dim lnPosition
Dim lsResult
Dim Char1
Dim Char2
Dim Char3
Dim Char4
Dim Byte1
Dim Byte2
Dim Byte3
Dim SaveBits1
Dim SaveBits2
Dim lsGroupBinary
Dim lsGroup64
Dim m4,len1,len2
len1=Lenb(asContents)
if len1<1 then
Base64encode=""
exit Function
end if
m3=Len1 Mod 3
If M3 > 0 Then asContents = asContents & String(3-M3, chrb(0))
'补足位数是为了便于计算
IF m3 > 0 THEN
len1=len1+(3-m3)
len2=len1-3
len2=len1
end if
lsResult = ""
For lnPosition = 1 To len2 Step 3
lsGroup64 = ""
lsGroupBinary = Midb(asContents, lnPosition, 3)
Byte1 = Ascb(Midb(lsGroupBinary, 1, 1)): SaveBits1 = Byte1 And 3
Byte2 = Ascb(Midb(lsGroupBinary, 2, 1)): SaveBits2 = Byte2 And 15
Byte3 = Ascb(Midb(lsGroupBinary, 3, 1))
Char1 = Midb(sBASE_64_CHARACTERS, ((Byte1 And 252) \ 4) + 1, 1)
Char2 = Midb(sBASE_64_CHARACTERS, (((Byte2 And 240) \ 16) Or (SaveBits1 * 16) And &HFF) + 1, 1)
Char3 = Midb(sBASE_64_CHARACTERS, (((Byte3 And 192) \ 64) Or (SaveBits2 * 4) And &HFF) + 1, 1)
Char4 = Midb(sBASE_64_CHARACTERS, (Byte3 And 63) + 1, 1)
lsGroup64 = Char1 & Char2 & Char3 & Char4
lsResult = lsResult & lsGroup64
Next
'处理最后剩余的几个字符
if M3 > 0 then
lsGroup64 = ""
lsGroupBinary = Midb(asContents, len2+1, 3)
if M3=1 then
lsGroup64 = Char1 & Char2 & ChrB(61) & ChrB(61) '用=号补足位数
lsGroup64 = Char1 & Char2 & Char3 & ChrB(61) '用=号补足位数
end if
end if
Base64encode = lsResult
End Function
Function Base64decode(asContents)
'将Base64编码字符串转换成Ansi编码的字符串
'asContents应当也是ANSI编码的字符串(二进制的字符串也可以)
Dim lsResult
Dim lnPosition
Dim lsGroup64, lsGroupBinary
Dim Char1, Char2, Char3, Char4
Dim Byte1, Byte2, Byte3
Dim M4,len1,len2
len1= Lenb(asContents)
M4 = len1 Mod 4
if len1 < 1 or M4 > 0 then
'字符串长度应当是4的倍数
Base64decode = ""
exit Function
end if
'判断最后一位是不是 = 号
'判断倒数第二位是不是 = 号
'这里m4表示最后剩余的需要单独处理的字符个数
if midb(asContents, len1, 1) = chrb(61) then m4=3
if midb(asContents, len1-1, 1) = chrb(61) then m4=2
if m4 = 0 then
len2=len1
len2=len1-4
end if
For lnPosition = 1 To Len2 Step 4
lsGroupBinary = ""
lsGroup64 = Midb(asContents, lnPosition, 4)
Char1 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 1, 1)) - 1
Char2 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 2, 1)) - 1
Char3 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 3, 1)) - 1
Char4 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 4, 1)) - 1
Byte1 = Chrb(((Char2 And 48) \ 16) Or (Char1 * 4) And &HFF)
Byte2 = lsGroupBinary & Chrb(((Char3 And 60) \ 4) Or (Char2 * 16) And &HFF)
Byte3 = Chrb((((Char3 And 3) * 64) And &HFF) Or (Char4 And 63))
lsGroupBinary = Byte1 & Byte2 & Byte3
lsResult = lsResult & lsGroupBinary
Next
'处理最后剩余的几个字符
if M4 > 0 then
lsGroupBinary = ""
lsGroup64 = Midb(asContents, len2+1, m4) & chrB(65) 'chr(65)=A,转换成值为0
if M4=2 then '补足4位,是为了便于计算
lsGroup64 = lsGroup64 & chrB(65)
end if
if M4=2 then
elseif M4=3 then
end if
end if
Base64decode = lsResult
End Function
If Request.ServerVariables("REQUEST_METHOD") = "POST" Then
plaintext=request.form("plaintext")
response.write "
输入的明文是:
"&replace(plaintext,chr(13),"
cryptext=Base64encode(plaintext)
response.write "
加密的密文是:
" &cryptext
decryptext=Base64decode(cryptext)
response.write "
解密的明文是:
" &replace(decryptext,chr(13),"
end if
请输入需要加密的明文:
[/code]
该文章在 2010/5/8 16:07:43 编辑过
