C#WinForm调用StiReport报表控件,实现打印模板格式自主设计、保存、预览、打印功能
2024年12月27日 21:43
本文热度 2268
下面给大家分享一套基于WinForm+StiReport的打印控件,可以实现自定义打印模板,数据源绑定、预览、保存、打印功能。
模板定义界面:
功能实现:
引用StiReport相关的dll:
项目生成:
部分代码展示:
private void button1_Click(object sender, EventArgs e) { StiDesigner designer = new StiDesigner(report); StiDesigner.SavingReport += StiDesigner_SavingReport; report.RegData("TableVo", new WeightVo() { Code = "", Name = "" }); report.Compile(); report.Design(); }
private void StiDesigner_SavingReport(object sender, StiSavingObjectEventArgs e) {
string outputDirectory = AppDomain.CurrentDomain.BaseDirectory; report.Save($"{outputDirectory}\\Report.mrt"); MessageBox.Show("保存成功!"); } private void button2_Click(object sender, EventArgs e) { string outputDirectory = AppDomain.CurrentDomain.BaseDirectory; report.Load($"{outputDirectory}\\Report.mrt"); report.RegData("TableVo", new WeightVo() { Code = "001", Name = "这是一个打印测试模板" }); report.Compile(); report.Show();
} private void button3_Click(object sender, EventArgs e) { string outputDirectory = AppDomain.CurrentDomain.BaseDirectory; report.Load($"{outputDirectory}\\Report.mrt"); report.RegData("TableVo", new WeightVo() { Code = "001", Name = "这是一个打印测试模板" }); report.Compile(); report.Print(); }
阅读原文:https://mp.weixin.qq.com/s/qtFLtSITEQJvxi3Bf35tXw
该文章在 2024/12/28 12:07:01 编辑过
