asp读取解析JSON的几种方法
2024年12月12日 17:57 本文热度 2157
方法一(使用MSScriptControl.ScriptControl):
Dim sc4Json,arr0,json
InitScriptControl
json="{""name"":""123"",""content"":[{""id"":""1""},{""id"":""2""}]}"
Set jsonobj=getJSONObject(json)
'方法一
getJSArrayItem arr0,jsonobj.content,0
response.write jsonobj.name&"<br/>"&arr0.id&"<br/>"
'方法二
response.write sc4Json.Eval("jsonObject.name")&"<br/>"
response.write sc4Json.Eval("jsonObject.content[1].id")
Sub InitScriptControl
  Set sc4Json = Server.CreateObject("MSScriptControl.ScriptControl")
  sc4Json.Language = "JavaScript"
  sc4Json.AddCode "var itemTemp=null;function getJSArray(arr, index){itemTemp=arr[index];}"
End Sub
Function getJSONObject( strJSON )
  sc4Json.AddCode "var jsonObject = " & strJSON
  Set getJSONObject = sc4Json.CodeObject.jsonObject
End Function
Sub getJSArrayItem( objDest, objJSArray, index )
  On Error Resume Next
  sc4Json.Run "getJSArray",objJSArray, index
  Set objDest = sc4Json.CodeObject.itemTemp
  If Err.number=0 Then  Exit Sub End If
End Sub
方法二:
Dim sc4Json
End Sub
Function getJSONObject(strJSON)
End Function
Sub getJSArrayItem(objDest,objJSArray,index)
End Sub
Dim strTest
strTest = "{name:""alonely"", age:24, email:[""ycplxl1314@163.com"",""ycplxl1314@gmail.com""], family:{parents:[""父亲"",""母亲""],toString:function(){return ""家庭成员"";}}}"
Dim objTest
Call InitScriptControl
Set objTest = getJSONObject(strTest)
<%=objTest.name%>的邮件地址是<%=sc4Json.eval_r("jsonObject.email[0]")%><BR>共有邮件地址<%=objTest.email.length%>个<BR>
Dim father
getJSArrayItem father, objTest.family.parents, 0
Response.Write father
方法三(类库):
'    VBS JSON 2.0.3
'    Copyright (c) 2009
'    Under the MIT (MIT-LICENSE.txt) license.
Const JSON_OBJECT    = 0
Const JSON_ARRAY    = 1
Class jsCore
Public Collection
Public Count
Public QuotedVars
Public Kind ' 0 = object, 1 = array
Private Sub Class_Initialize
  Set Collection = CreateObject("Scripting.Dictionary")
  QuotedVars = True
  Count = 0
End Sub
Private Sub Class_Terminate
  Set Collection = Nothing
End Sub
' counter
Private Property Get Counter
  Counter = Count
  Count = Count + 1
End Property
' – data maluplation
' — pair
Public Property Let Pair(p, v)
  If IsNull(p) Then p = Counter
  Collection(p) = v
End Property
Public Property Set Pair(p, v)
  If TypeName(v) <> "jsCore" Then
    Err.Raise &hD, "class: class", "Incompatible types: '" & TypeName(v) & "'"
  End If
  Set Collection(p) = v
End Property
Public Default Property Get Pair(p)
  If IsNull(p) Then p = Count – 1
  If IsObject(Collection(p)) Then
    Set Pair = Collection(p)
  Else
  End If
End Property
' — pair
Public Sub Clean
  Collection.RemoveAll
End Sub
Public Sub Remove(vProp)
  Collection.Remove vProp
End Sub
' data maluplation
' encoding
Function jsEncode(str)
  Dim charmap(127), haystack()
  charmap(8)  = "\b"
  charmap(9)  = "\t"
  charmap(10) = "\n"
  charmap(12) = "\f"
  charmap(13) = "\r"
  charmap(34) = "\"""
  charmap(47) = "\/"
  charmap(92) = "\\"
  Dim strlen : strlen = Len(str) – 1
  ReDim haystack(strlen)
  Dim i, charcode
  For i = 0 To strlen
    haystack(i) = Mid(str, i + 1, 1)
    charcode = AscW(haystack(i)) And 65535
    If charcode < 127 Then
      If Not IsEmpty(charmap(charcode)) Then
        haystack(i) = charmap(charcode)
      ElseIf charcode < 32 Then
        haystack(i) = "\u" & Right("000″ & Hex(charcode), 4)
      End If
    Else
    End If
  Next
  jsEncode = Join(haystack, "")
End Function
' converting
Public Function toJSON(vPair)
  Select Case VarType(vPair)
  Case 0    ’ Empty
  toJSON = "null"
  Case 1    ’ Null
  toJSON = "null"
  Case 7    ’ Date
  ' toJSON = "new Date(" & (vPair – CDate(25569)) * 86400000 & ")"    ’ let in only utc time
  toJSON = """" & CStr(vPair) & """"
  Case 8    ’ String
  toJSON = """" & jsEncode(vPair) & """"
  Case 9    ’ Object
  Dim bFI,i
  bFI = True
  If vPair.Kind Then toJSON = toJSON & "[" Else toJSON = toJSON & "{"
  For Each i In vPair.Collection
    If bFI Then bFI = False Else toJSON = toJSON & ","
    If vPair.Kind Then
      toJSON = toJSON & toJSON(vPair(i))
    Else
      If QuotedVars Then
        toJSON = toJSON & """" & i & """:" & toJSON(vPair(i))
      Else
        toJSON = toJSON & i & ":" & toJSON(vPair(i))
      End If
    End If
  Next
  If vPair.Kind Then toJSON = toJSON & "]" Else toJSON = toJSON & "}"
  Case 11
    If vPair Then toJSON = "true" Else toJSON = "false"
  Case 12, 8192, 8204
    toJSON = RenderArray(vPair, 1, "")
  Case Else
    toJSON = Replace(vPair, ",", ".")
  End select
End Function
Function RenderArray(arr, depth, parent)
  Dim first : first = LBound(arr, depth)
  Dim last : last = UBound(arr, depth)
  Dim index, rendered
  Dim limiter : limiter = ","
  RenderArray = "["
  For index = first To last
    If index = last Then limiter = ""
    rendered = RenderArray(arr, depth + 1, parent & index & "," )
    If Err = 9 Then
      On Error GoTo 0
      RenderArray = RenderArray & toJSON(Eval("arr(" & parent & index & ")")) & limiter
    Else
      RenderArray = RenderArray & rendered & "" & limiter
    End If
  Next
  RenderArray = RenderArray & "]"
End Function
Public Property Get jsString
  jsString = toJSON(Me)
End Property
Sub Flush
  If TypeName(Response) <> "Empty" Then
    Response.Write(jsString)
  ElseIf WScript <> Empty Then
    WScript.Echo(jsString)
  End If
End Sub
Public Function Clone
  Set Clone = ColClone(Me)
End Function
Private Function ColClone(core)
  Dim jsc, i
  Set jsc = new jsCore
  jsc.Kind = core.Kind
  For Each i In core.Collection
    If IsObject(core(i)) Then
      Set jsc(i) = ColClone(core(i))
    Else
      jsc(i) = core(i)
    End If
  Next
  Set ColClone = jsc
End Function
End Class
Function jsObject
  Set jsObject = new jsCore
  jsObject.Kind = JSON_OBJECT
End Function
Function jsArray
  Set jsArray = new jsCore
  jsArray.Kind = JSON_ARRAY
End Function
Function toJSON(val)
  toJSON = (new jsCore).toJSON(val)
End Function
类库提供了两种js类型,object和array,使用方法如下:
Set hash = jsObject() '如果要输出array就写Set hash=jsArray()
hash("error") = 0
hash("url") = fileUrl
hash.Flush
Response.End
输出的就是json格式的字符串了
该文章在 2024/12/12 17:58:24 编辑过
