js动态给table加上合计行
2024年12月6日 9:37 本文热度 2649
:js动态给table加上合计行
<script>
function sortTableByColumn_count(myTable, columnIndex, isNumber) {
const table = document.getElementById(myTable);
var tb
ody = table.tBodies[0];
  var rows = Array.from(tbody.rows);
  var firstRow = rows.shift();
  tbody.deleteRow(0); // 移除原始的表头
  table.insertBefore(firstRow, tbody); // 将表头重新添加到表格
  rows.sort(function(a, b) {
    var cellA = a.cells[columnIndex];
    var cellB = b.cells[columnIndex];
    if (isNumber) {
      return parseFloat(cellA.textContent) - parseFloat(cellB.textContent);
    } else {
      return cellA.textContent.localeCompare(cellB.textContent);
  // 计算每个数值出现的次数
  var counts = rows.reduce(function(counts, row) {
    var value = row.cells[columnIndex].textContent;
    counts[value] = (counts[value] || 0) + 1;
    return counts;
  // 根据出现次数倒序排序
    return counts[b.cells[columnIndex].textContent] - counts[a.cells[columnIndex].textContent];
  for(var i = 0; i < rows.length; i++) {
    tbody.appendChild(rows[i]);
function deleteLastRow(myTable) {
  var table = document.getElementById(myTable); // 获取table元素
  var rows = table.getElementsByTagName("tr"); // 获取所有行
  if (rows.length > 1) { // 确保至少还有一行
    table.deleteRow(rows.length - 1); // 删除最后一行
function insertlasttr(myTable){
var existingRow = table.rows[0];
var newRow = table.insertRow(-1);
for (var k = 0; k < table.rows[0].cells.length; k++) {
var newCell = newRow.insertCell(k);
newCell.rowSpan = existingRow.cells[k].rowSpan;
newCell.colSpan = existingRow.cells[k].colSpan;
newCell.style.cssText = existingRow.cells[k].style.cssText;
function countvalueshow(myTable,colindex){
const rows = table.getElementsByTagName('tr');
const colCount = colindex; // 第二列的索引是1,因为索引从0开始
let countMap = {};
for (let i = 1; i < rows.length; i++) { // 跳过表头
  const cell = rows[i].getElementsByTagName('td')[colCount];
  const age = cell.textContent.trim();
  if (countMap[age]) {
countMap[age].count++;
  } else {
   countMap[age] = {
       count: 1
return countMap;
function updateSerialNumbers(middleTable) {
    const table = document.getElementById(middleTable);
    const rows = table.getElementsByTagName("tbody")[0].getElementsByTagName("tr");
    let serialNum = 1;
        const row = rows[i];
        // 检查行是否为可见
        if (row.style.display !== "none") {
            // 将序号设置到第一列
            row.cells[0].innerText = serialNum;
            serialNum++;
// 调用函数以更新序号
function sortTableByColumn(myTable, columnIndex) {
  var tbody = table.tBodies[0];
  var rows = Array.prototype.slice.call(tbody.rows, 1);
    if (cellA.textContent < cellB.textContent) {
      return -1;
    if (cellA.textContent > cellB.textContent) {
      return 1;
    return 0;
  table.removeChild(tbody);
  for (var i = 0; i < rows.length; i++) {
  table.appendChild(tbody);
function insertSumRow(tableId, columnIndex,totalindex) {
  var table = document.getElementById(tableId);
  var existingRow ;
  var secondRowStyle;
  var rows = table.rows;
  for (var i = 1; i < rows.length - 1; i++) {
    var currentCellValue = rows[i].cells[columnIndex].innerText;
    var nextCellValue = rows[i + 1].cells[columnIndex].innerText;
secondRowStyle = window.getComputedStyle(table.rows[i]);
existingRow = table.rows[i];
objArray=countvalueshow('myTable',columnIndex)
    if (currentCellValue !== nextCellValue&&objArray[currentCellValue].count>1) {
      // 创建合计行并插入
      var newRow = table.insertRow(i + 1);
  for (var j = 0; j < secondRowStyle.length; j++) {
      var prop = secondRowStyle[j];
      newRow.style[prop] = secondRowStyle.getPropertyValue(prop);
     // 设置单元格的rowSpan和colSpan属性
     // 设置单元格内容和样式
if(k==0){
  newCell.textContent = "合计:";
else if(k==totalindex){
newCell.textContent ="";
else {
  newCell.textContent = existingRow.cells[k].textContent;
      i++; // 行数增加1,因为插入了新行
function sumThirdColumnExceptTotal(myTable,colindex,totalcolindex) {
  var table = document.getElementById(myTable); // 获取表格元素
  var sum = 0;
  var end=1;
  // 从第二行开始遍历
  for (var i = 1, row; row = table.rows[i]; i++) {
    // 获取第一列的文本内容
    var firstCellText = row.cells[colindex].textContent || row.cells[colindex].innerText;
    // 如果包含“合计”字样,跳过累加
    if (firstCellText.includes('合计')) {
     for (var k = end;k<i; k++) {
if(table.rows[k].cells[3].textContent==table.rows[k+1].cells[3].textContent){
sum=sum-(-table.rows[k].cells[totalcolindex].textContent);
table.rows[i].cells[totalcolindex].textContent=sum;
sum = 0;
end=i+1;
//首先给按第某列内容排序
sortTableByColumn_count("myTable", 3, true);
//排序完后更新序号
updateSerialNumbers("myTable");
//插入一条空白行
insertlasttr("myTable");
//添加一行合计行
insertSumRow('myTable',3,6);
//最后给合计合计数量
sumThirdColumnExceptTotal('myTable',0,6);
//删除最后一条空白行
deleteLastRow("myTable");
</script>
该文章在 2024/12/6 9:37:35 编辑过
