univer表格应用及案例
2024年7月25日 12:2 本文热度 3210
一、Univer介绍
Univer 是 Office 系列办公套件的开源替代品,包括电子表格、文档和幻灯片。目前提供公式、数字格式、条件格式、数据验证、图文混排等功能。你可以将 Univer 集成到你的系统当中,并基于 Univer 开发个性化的业务需求。
二、使用步骤
1、使用UMD
<scriptsrc="https://unpkg.com/@univerjs/umd/lib/univer.full.umd.js"></script> <linkrel="stylesheet"href="https://unpkg.com/@univerjs/umd/lib/univer.css">
将上边两个链接复制到浏览器打开,另存为进行下载到本地
引入到publish/index.html中
组件内使用
<template>
  <div ref="sheetContainer" style="height: 100%"></div>
</template>
<script setup>
const {
  UniverCore,
  UniverDesign,
  UniverEngineRender,
  UniverEngineFormula,
  UniverDocs,
  UniverDocsUi,
  UniverUi,
  UniverSheets,
  UniverSheetsUi,
  UniverSheetsNumfmt,
  UniverSheetsFormula,
  UniverFacade,
} = window;
const props = defineProps({
  data: {
    type: Object,
    default: () => ({}),
const univerRef = ref(null);
const workbook = ref(null);
const sheetContainer = ref(null);
const univerAPI = ref(null);
const init = (data) => {
  const univer = new UniverCore.Univer({
    theme: UniverDesign.defaultTheme,
  univerRef.value = univer;
  univer.registerPlugin(UniverEngineRender.UniverRenderEnginePlugin);
  univer.registerPlugin(UniverEngineFormula.UniverFormulaEnginePlugin);
  univer.registerPlugin(UniverUi.UniverUIPlugin, {
    container: sheetContainer.value,
  univer.registerPlugin(UniverDocs.UniverDocsPlugin, {
    hasScroll: false,
  univer.registerPlugin(UniverDocsUi.UniverDocsUIPlugin);
  univer.registerPlugin(UniverSheets.UniverSheetsPlugin);
  univer.registerPlugin(UniverSheetsUi.UniverSheetsUIPlugin);
  univer.registerPlugin(UniverSheetsNumfmt.UniverSheetsNumfmtPlugin);
  univer.registerPlugin(UniverSheetsFormula.UniverSheetsFormulaPlugin);
  workbook.value = univer.createUniverSheet(data);
  univerAPI.value = UniverFacade.FUniver.newAPI(univer);
onMounted(() => {
  init(props.data);
const getData = () => {
  if (!workbook.value) {
    throw new Error('Workbook is not initialized');
  return workbook.value.save();
defineExpose({
  getData,
  univerAPI: univerAPI.value,
</script>
2、npm安装
npm install @univerjs/core @univerjs/design @univerjs/docs @univerjs/docs-ui @univerjs/engine-formula @univerjs/engine-render @univerjs/sheets @univerjs/sheets-formula @univerjs/sheets-ui @univerjs/ui
npm install @univerjs/facade
三、表格数据结构
 * Copyright 2023-present DreamNum Inc.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
var { UniverCore } = window;
 * Default workbook data
 * @type {IWorkbookData} document see https://univer.work/api/core/interfaces/IWorkbookData.html
export const DEFAULT_WORKBOOK_DATA = {
  locale: UniverCore.LocaleType.ZH_CN,
  sheetOrder: ['sheet-01', 'sheet-02', 'sheet-03'],
  appVersion: '3.0.0-alpha',
  sheets: {
    'sheet-01': {
      type: UniverCore.SheetTypes.GRID,
      cellData: {
        0: {
          0: {
            v: 'Hello World',
      tabColor: 'red',
      hidden: UniverCore.BooleanNumber.FALSE,
      rowCount: 1000,
      columnCount: 20,
      zoomRatio: 1,
      scrollTop: 200,
      scrollLeft: 100,
      defaultColumnWidth: 93,
      defaultRowHeight: 27,
      status: 1,
      showGridlines: 1,
      hideRow: [],
      hideColumn: [],
      rowHeader: {
        width: 46,
      columnHeader: {
        height: 20,
      selections: ['A2'],
      rightToLeft: UniverCore.BooleanNumber.FALSE,
      pluginMeta: {},
    'sheet-02': {
      cellData: {},
    'sheet-03': {
      cellData: {},
四、API
// 获取当前表数据
const activeSheet = univerAPI.getActiveWorkbook().getActiveSheet()
// 设置单元格 value
 const range = activeSheet.getRange(0, 0)
 if (!range) {
   throw new Error('range is not defined')
range.setValue(value)
// 设置某个范围单元格数据
 const values = [
  ['Hello', 'World!'],
  ['Hello', 'Univer!'],
const range = activeSheet.getRange(0, 0, values.length, values[0].length)
// getRange对应的从第0行第0列,到第X行,第X列(索引0开始)
if (!range)
range.setValues(values)
// 获取某个单元格value =>getRange=>第X行,第X列, 到 到第X行,第X列(索引0开始)
const range = activeSheet.getRange(0, 0, 2, 2)
if (!range)
const data = []
range.forEach((row, col, cell) => {
  data[row] = data[row] || []
  data[row][col] = cell.v?.toString()
// 获取workbookData 和传入的数据格式一致
const activeWorkbook = univerAPI.getActiveWorkbook()
console.log(JSON.stringify(activeWorkbook.getSnapshot(), null, 2))
// 获取sheetData 数据 -> 是获取workbookData中的sheet中的data
if (!activeWorkbook)
  throw new Error('activeWorkbook is not defined')
const snapshot = activeWorkbook.getSnapshot()
const sheet1 = Object.values(snapshot.sheets).find((sheet) => {
  return sheet.id === 'sheet-01'
// 创建sheet
const sheet = activeWorkbook.create('Sheet2', 10, 10) // 设置10行10列表格
// scroll to B100
univerAPI.executeCommand('sheet.command.scroll-to-cell', {
  range: {
    // top 设置 0 0
    startColumn: 1,
    startRow: 99,
// scroll to bottom
const { rowCount } = activeSheet._worksheet.getSnapshot()
  range: {
    startColumn: 0,
    startRow: rowCount - 1,
// 设置单元格背景
const range = activeSheet.getRange(0, 0, 1, 1)
range?.setBackgroundColor('red')
// 聚焦单元格
const subUnitId = activeSheet._worksheet.getSheetId()
univerAPI.executeCommand('sheet.operation.set-selections', {
  selections: [{
    range: {
      startRow: 0,
      startColumn: 0,
      endRow: 0,
      endColumn: 0,
      rangeType: 0,
  subUnitId,
  unitId: activeWorkbook.getId(),
  type: 2,
// 清除A1 styles
await univerAPI.executeCommand('sheet.operation.set-selections', {
  selections: [{
    range: {
      startRow: 0,
      startColumn: 0,
      endRow: 0,
      endColumn: 0,
      rangeType: 0,
  subUnitId,
  type: 2,
univerAPI.executeCommand('sheet.command.clear-selection-format')
五、案例应用:univer在线协同表格
使用node.js搭建websorket
后端代码:
//创建一个WebSocket服务器,在8080端口启动
const WebSocket = require('ws');
const server = new WebSocket.Server({ port: 8089 });
// 监听前端连接websocket(ws.on的connection事件)
server.on('connection', function connection(ws, req) {
  const ip = req.socket.remoteAddress;
  const port = req.socket.remotePort;
  const clientName = ip + port;
  console.log('%s is connected ', clientName);
//只要有WebSocket连接到该服务器,就会触发'connection'事件;req对象可以用来获取客户端的信息,如ip、端口号
//获取所有已连接的客户端信息,则可以使用server.clients数据集
// 服务器接收数据(ws.on的message事件)
module.exports.listener = () => {
  server.on('connection', (ws, req) => {
    console.log('有客户端连接成功了', ws, req);
    // 对客户端的连接对象进行message事件的监听
    // 当客户端有消息发送给服务器时,服务器就能够触发该消息
    // msg:由客户端发给服务端的数据
    ws.on('message', (msg = {}) => {
      console.log('客户端发送给服务器端', msg);
      // 当接收到客户端传的参数之后服务器端可以执行某些操作(具体看需求)
      // 小编这里是做了一个数据返回给客户端
      // 是当客户端连接成功之后会发送一条信息告诉服务器,服务器监听到信息之后再返回数据给客户端
      // 由服务端往客户端发送数据
      server.clients.forEach((client) => {
        console.log(client, 'client');
        // client.send(JSON.stringify(info));
        client.send(msg);
前端代码:
<template>
  <div>
    <div id="univerContainer" style="height: 500px"></div>
  </div>
</template>
<script setup>
var {
  UniverCore,
  UniverDesign,
  UniverEngineRender,
  UniverDocs,
  UniverDocsUi,
  UniverUi,
  UniverSheets,
  UniverSheetsUi,
  UniverSheetsNumfmt,
  UniverFacade,
} = window;
var univer = new UniverCore.Univer({
  container: 'univerContainer',
  hasScroll: false,
univer.createUniverSheet({
  sheets: {
    'sheet-01': {
      cellData: {},
const univerAPI = UniverFacade.FUniver.newAPI(univer);
const ws = univerAPI.createSocket('ws://localhost:8089');
ws.open$.subscribe(() => {
  console.log('websocket opened');
  // ws.send('hello')
ws.message$.subscribe((message) => {
  console.log('websocket message', JSON.parse(message.data));
  const content = JSON.parse(message.data);
  console.log('content', content);
  const { command, options } = content;
  const { id, params } = command;
  console.log(params, 'params--------');
  // 接受到协同数据,本地落盘
  univerAPI.executeCommand(id, params, options);
ws.close$.subscribe(() => {
  console.log('websocket closed');
ws.error$.subscribe((error) => {
  console.log('websocket error', error);
univerAPI.onCommandExecuted((command, options) => {
  // 仅同步本地 mutation
  if (
    command.type !== 2 ||
    options?.fromCollab ||
    options?.onlyLocal ||
    command.id === 'doc.mutation.rich-text-editing'
    return;
  const commandInfo = JSON.stringify({
    command,
    options: { fromCollab: true },
  console.log(commandInfo, 'commandInfo');
  ws.send(commandInfo);
</script>
注意:必须指定id才能协同
  sheets: {
    'sheet-01': {
      cellData: {},
版权声明:本文为博主原创文章,遵循 CC 4.0 BY-SA 版权协议,转载请附上原文出处链接和本声明。
原文链接:https://blog.csdn.net/m0_73884922/article/details/139971295
该文章在 2024/7/25 12:02:14 编辑过
