3个SQL视图搞定所有SqlServer数据库字典
2011年10月10日 10:10
本文热度 4138
1. SqlServer数据库字典--表结构.sql
以下是引用片段: SELECT TOP 100 PERCENT --a.id, CASE WHEN a.colorder = 1 THEN d.name ELSE '' END AS 表名, CASE WHEN a.colorder = 1 THEN isnull(f.value, '') ELSE '' END AS 表说明, a.colorder AS 字段序号, a.name AS 字段名, CASE WHEN COLUMNPROPERTY(a.id, a.name, 'IsIdentity') = 1 THEN '√' ELSE '' END AS 标识, CASE WHEN EXISTS (SELECT 1 FROM dbo.sysindexes si INNER JOIN dbo.sysindexkeys sik ON si.id = sik.id AND si.indid = sik.indid INNER JOIN dbo.syscolumns sc ON sc.id = sik.id AND sc.colid = sik.colid INNER JOIN dbo.sysobjects so ON so.name = so.name AND so.xtype = 'PK' WHERE sc.id = a.id AND sc.colid = a.colid) THEN '√' ELSE '' END AS 主键, b.name AS 类型, a.length AS 长度, COLUMNPROPERTY(a.id, a.name, 'PRECISION') AS 精度, ISNULL(COLUMNPROPERTY(a.id, a.name, 'Scale'), 0) AS 小数位数, CASE WHEN a.isnullable = 1 THEN '√' ELSE '' END AS 允许空, ISNULL(e.text, '') AS 默认值, ISNULL(g.[value], '') AS 字段说明, d.crdate AS 创建时间, CASE WHEN a.colorder = 1 THEN d.refdate ELSE NULL END AS 更改时间 FROM dbo.syscolumns a LEFT OUTER JOIN dbo.systypes b ON a.xtype = b.xusertype INNER JOIN dbo.sysobjects d ON a.id = d.id AND d.xtype = 'U' AND d.status >= 0 LEFT OUTER JOIN dbo.syscomments e ON a.cdefault = e.id LEFT OUTER JOIN dbo.sysproperties g ON a.id = g.id AND a.colid = g.smallid LEFT OUTER JOIN dbo.sysproperties f ON d.id = f.id AND f.smallid = 0 ORDER BY d.name, a.colorder |
2. SqlServer数据库字典--索引.sql
以下是引用片段: SELECT TOP 100 PERCENT --a.id, CASE WHEN b.keyno = 1 THEN c.name ELSE '' END AS 表名, CASE WHEN b.keyno = 1 THEN a.name ELSE '' END AS 索引名称, d.name AS 列名, b.keyno AS 索引顺序, CASE indexkey_property(c.id, b.indid, b.keyno, 'isdescending') WHEN 1 THEN '降序' WHEN 0 THEN '升序' END AS 排序, CASE WHEN p.id IS NULL THEN '' ELSE '√' END AS 主键, CASE INDEXPROPERTY(c.id, a.name, 'IsClustered') WHEN 1 THEN '√' WHEN 0 THEN '' END AS 聚集, CASE INDEXPROPERTY(c.id, a.name, 'IsUnique') WHEN 1 THEN '√' WHEN 0 THEN '' END AS 唯一, CASE WHEN e.id IS NULL THEN '' ELSE '√' END AS 唯一约束, a.OrigFillFactor AS 填充因子, c.crdate AS 创建时间, c.refdate AS 更改时间 FROM dbo.sysindexes a INNER JOIN dbo.sysindexkeys b ON a.id = b.id AND a.indid = b.indid INNER JOIN dbo.syscolumns d ON b.id = d.id AND b.colid = d.colid INNER JOIN dbo.sysobjects c ON a.id = c.id AND c.xtype = 'U' LEFT OUTER JOIN dbo.sysobjects e ON e.name = a.name AND e.xtype = 'UQ' LEFT OUTER JOIN dbo.sysobjects p ON p.name = a.name AND p.xtype = 'PK' WHERE (OBJECTPROPERTY(a.id, N'IsUserTable') = 1) AND (OBJECTPROPERTY(a.id, N'IsMSShipped') = 0) AND (INDEXPROPERTY(a.id, a.name, 'IsAutoStatistics') = 0) ORDER BY c.name, a.name, b.keyno |
3. SqlServer数据库字典--主键.外键.约束.视图.函数.存储过程.触发器.sql
以下是引用片段: SELECT DISTINCT TOP 100 PERCENT o.xtype, CASE o.xtype WHEN 'X' THEN '扩展存储过程' WHEN 'TR' THEN '触发器' WHEN 'PK' THEN '主键' WHEN 'F' THEN '外键' WHEN 'C' THEN '约束' WHEN 'V' THEN '视图' WHEN 'FN' THEN '函数-标量' WHEN 'IF' THEN '函数-内嵌' WHEN 'TF' THEN '函数-表值' ELSE '存储过程' END AS 类型, o.name AS 对象名, o.crdate AS 创建时间, o.refdate AS 更改时间, c.text AS 声明语句 FROM dbo.sysobjects o LEFT OUTER JOIN dbo.syscomments c ON o.id = c.id WHERE (o.xtype IN ('X', 'TR', 'C', 'V', 'F', 'IF', 'TF', 'FN', 'P', 'PK')) AND (OBJECTPROPERTY(o.id, N'IsMSShipped') = 0) ORDER BY CASE o.xtype WHEN 'X' THEN '扩展存储过程' WHEN 'TR' THEN '触发器' WHEN 'PK' THEN '主键' WHEN 'F' THEN '外键' WHEN 'C' THEN '约束' WHEN 'V' THEN '视图' WHEN 'FN' THEN '函数-标量' WHEN 'IF' THEN '函数-内嵌' WHEN 'TF' THEN '函数-表值' ELSE '存储过程' END DESC |
该文章在 2011/10/10 10:10:25 编辑过
全部评论2 |
2011年10月10日 10:26
SELECT 表名 = CASE WHEN a.colorder = 1 THEN d .name ELSE '' END,
字段序号 = a.colorder, 字段名 = a.name,
标识 = CASE WHEN COLUMNPROPERTY(a.id, a.name, 'IsIdentity')
= 1 THEN '√' ELSE '' END, 类型 = b.name, 占用字节数 = a.length,
长度 = COLUMNPROPERTY(a.id, a.name, 'PRECISION'),
小数位数 = isnull(COLUMNPROPERTY(a.id, a.name, 'Scale'), 0),
允许空 = CASE WHEN a.isnullable = 1 THEN '√' ELSE '' END, 默认值 = isnull(e.text,
''), 字段说明 = isnull(g.[value], '')
FROM syscolumns a LEFT JOIN
sysobjects d ON a.id = d .id AND d .xtype = 'U' AND d .name <> 'dtproperties' LEFT
JOIN
syscomments e ON a.cdefault = e.id LEFT JOIN
ORDER BY a.id, a.colorder 该评论在 2011/10/10 10:26:37 编辑过
Ccoffee
2025年4月14日 10:26
SELECT 表名 = CASE WHEN a.colorder = 1 THEN d .name ELSE '' END, 字段序号 = a.colorder, 字段名 = a.name, 标识 = CASE WHEN COLUMNPROPERTY(a.id, a.name, 'IsIdentity') = 1 THEN '√' ELSE '' END, 类型 = b.name, 占用字节数 = a.length, 长度 = COLUMNPROPERTY(a.id, a.name, 'PRECISION'), 小数位数 = isnull(COLUMNPROPERTY(a.id, a.name, 'Scale'), 0), 允许空 = CASE WHEN a.isnullable = 1 THEN '√' ELSE '' END, 默认值 = isnull(e.text, ''), 字段说明 = isnull(g.[value], '') FROM syscolumns a LEFT JOIN systypes b ON a.xtype = b.xusertype INNER JOIN sysobjects d ON a.id = d .id AND d .xtype = 'U' AND d .name <> 'dtproperties' LEFT JOIN syscomments e ON a.cdefault = e.id LEFT JOIN dtproperties g ON a.id = g.id AND a.colid = g.id ORDER BY a.id, a.colorder
