| 推荐一个C#开发的、跨平台的解压缩的开源项,值得收藏
					当前位置:点晴教程→知识管理交流
					→『 技术文档交流 』
 项目简介项目结构 压缩核心代码 protected void Write(CompressionType compressionType, string archive, string archiveToVerifyAgainst, Encoding encoding = null) { using (Stream stream = File.OpenWrite(Path.Combine(SCRATCH2_FILES_PATH, archive))) { WriterOptions writerOptions = new WriterOptions(compressionType) { LeaveStreamOpen = true, };
 writerOptions.ArchiveEncoding.Default = encoding ?? Encoding.Default;
 using (var writer = WriterFactory.Open(stream, type, writerOptions)) { writer.WriteAll(ORIGINAL_FILES_PATH, "*", SearchOption.AllDirectories); } } CompareArchivesByPath(Path.Combine(SCRATCH2_FILES_PATH, archive), Path.Combine(TEST_ARCHIVES_PATH, archiveToVerifyAgainst));
 using (Stream stream = File.OpenRead(Path.Combine(SCRATCH2_FILES_PATH, archive))) { ReaderOptions readerOptions = new ReaderOptions();
 readerOptions.ArchiveEncoding.Default = encoding ?? Encoding.Default;
 using (var reader = ReaderFactory.Open(NonDisposingStream.create(stream), readerOptions)) { reader.WriteAllToDirectory(SCRATCH_FILES_PATH, new ExtractionOptions() { ExtractFullPath = true }); } } VerifyFiles(); } 解压核心代码 public abstract class ReaderTests : TestBase { protected void Read(string testArchive, CompressionType expectedCompression, ReaderOptions options = null) { testArchive = Path.Combine(TEST_ARCHIVES_PATH, testArchive);
 options = options ?? new ReaderOptions();
 options.LeaveStreamOpen = true; ReadImpl(testArchive, expectedCompression, options);
 options.LeaveStreamOpen = false; ReadImpl(testArchive, expectedCompression, options); VerifyFiles(); }
 private void ReadImpl(string testArchive, CompressionType expectedCompression, ReaderOptions options) { using (var file = File.OpenRead(testArchive)) { using (var protectedStream = NonDisposingStream.create(new ForwardOnlyStream(file), throwOnDispose: true)) { using (var testStream = new TestStream(protectedStream)) { using (var reader = ReaderFactory.Open(testStream, options)) { UseReader(reader, expectedCompression); protectedStream.ThrowOnDispose = false; Assert.False(testStream.IsDisposed, "{nameof(testStream)} prematurely closed"); }
 // Boolean XOR -- If the stream should be left open (true), then the stream should not be diposed (false) // and if the stream should be closed (false), then the stream should be disposed (true) var message = $"{nameof(options.LeaveStreamOpen)} is set to '{options.LeaveStreamOpen}', so {nameof(testStream.IsDisposed)} should be set to '{!testStream.IsDisposed}', but is set to {testStream.IsDisposed}"; Assert.True(options.LeaveStreamOpen != testStream.IsDisposed, message); } } } }
 public void UseReader(IReader reader, CompressionType expectedCompression) { while (reader.MoveToNextEntry()) { if (!reader.Entry.IsDirectory) { Assert.Equal(expectedCompression, reader.Entry.CompressionType); reader.WriteEntryToDirectory(SCRATCH_FILES_PATH, new ExtractionOptions() { ExtractFullPath = true, Overwrite = true }); } } } } zip压缩用法 Write(CompressionType.None, "Zip.none.noEmptyDirs.zip", "Zip.none.noEmptyDirs.zip", Encoding.UTF8); zip解压用法 Read("Zip.zipx", CompressionType.LZMA);
 该文章在 2023/8/16 9:39:40 编辑过 | 关键字查询 相关文章 正在查询... |
