点晴ERP-还原图片路径函数
2023年7月6日 16:18 本文热度 1931
:点晴ERP-还原图片路径函数
在ASP文件上添加以下函数代码:
'正则表达式匹配字符串函数
Function regx(patrn, str)
 Dim regEx, Match, Matches
 Set regEx = New RegExp
 regEx.Pattern = patrn
 regEx.IgnoreCase = True
 regEx.Global = True
 Set Matches = regEx.execute(str)
 For Each Match in Matches
 RetStr = RetStr & Match.Value & " "
 Next
 regx = RetStr
End Function
'获取图片实际的路径函数
Function decryption_imgpath (Y_images_path)
    if isNull(Y_images_path) then
    if Instr(Y_images_path,"read.ashx")>0 then
    Y_images_path=regx("img.*?uploadlog_code",Y_images_path)
Y_images_path=regx("c=2.*?uploadlog_code",Y_images_path)
Y_images_path=replace(Y_images_path,"c=","")
Y_images_path=replace(Y_images_path,"uploadlog_code","")
Y_images_path=replace(Y_images_path," ","")
Y_images_path=replace(Y_images_path,"&","")
Y_images_path=replace(Y_images_path,"amp;","")
set rs_all=server.createobject("adodb.recordset")
    sql_all="select * from mis_uploader_fileinf   where  visitcode like" & sqlstr("%"&Y_images_path&"%")
    'response.write sql_all
     rs_all.Open sql_all,conn,3,1
     if rs_all.recordcount>0 then
    file_physical_path=rs_all("file_physical_path")
    file_physical_path=replace(file_physical_path,"C:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"D:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"E:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"F:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"G:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"H:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"I:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"J:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"K:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"\","/")
    img_html="<img src='"&file_physical_path&"' style=""width:100%;"">"
    Y_images_path=img_html
     end if
      rs_all.close
    end if
    end if
     decryption_imgpath=Y_images_path
      End Function
调用函数即可
Y_images=rs("Y_images")
Y_images=decryption_imgpath(Y_images)
该文章在 2023/7/6 16:18:06 编辑过
