- SQL code
declare @ProductName nvarchar(50)
declare pcurr cursor for select ProductName from Products
open pcurr
fetch next from pcurr into @ProductName
while (@@fetch_status = 0)
begin
print (@ProductName)
end
close pcurr
deallocate pcurr
open pcurr
begin
end
close pcurr
deallocate pcurr
此方法适用所有情况,对标结构没有特殊要求。
方法二:使用循环
- SQL code
declare @ProductID int
select @ProductID=min(ProductID) from Products
while @ProductID is not null
begin
select @ProductName=ProductName from Products where
ProductID=@ProductID
print(@ProductName);
select @ProductID=min(ProductID) from Products where
ProductID>@ProductID
end
begin
end
此方法适用于表带有自动增加标识的字段
400 186 1886
