C#图片复制、粘贴、打开、保存、取一小块图、抓屏截图
2021年1月20日 11:12 本文热度 4050
      //复制图像
       private void button4_Click(object sender, EventArgs e)
           Clipboard.SetDataObject(pictureBox3.Image);
       //粘贴图像
       private void button5_Click(object sender, EventArgs e)
           IDataObject iData = Clipboard.GetDataObject();
           if (iData.GetDataPresent(DataFormats.Bitmap))
               pictureBox4.Image = (Bitmap)iData.GetData(DataFormats.Bitmap);
       //打开图像
       private void button6_Click(object sender, EventArgs e)
           OpenFileDialog ofdlg = new OpenFileDialog();
           ofdlg.Filter = "BMP File(*.bmp)|*.bmp";
           if (ofdlg.ShowDialog() == DialogResult.OK)
               Bitmap image = new Bitmap(ofdlg.FileName);
               pictureBox4.Image = image;
       //保存图像
       private void button7_Click(object sender, EventArgs e)
           string str;
           Bitmap box1 = new Bitmap(pictureBox4.Image);
           SaveFileDialog sfdlg = new SaveFileDialog();
           sfdlg.Filter = "bmp文件(*.BMP)|*.BMP|All File(*.*)|*.*";
           sfdlg.ShowDialog();
           str = sfdlg.FileName;
           box1.Save(str);
       //取一小块图
       private void button9_Click(object sender, EventArgs e)
           //axPictureClip1.Picture = pictureBox4.Image;
           //axPictureClip1.Cols = 6;//将图片分成6列 axPictureClip1在COM组建里Microsoft Picture Clip Control
           //axPictureClip1.Rows = 3;//将图片分成3行
           //try
           //   pictureBox5.Image = axPictureClip1.get_GraphicCell(0);//取出一小块
           //catch(Exception ex)
           //   MessageBox.Show(ex.ToString());
           axPictureClip1.ClipX = 15;
           axPictureClip1.ClipY = 15;
           axPictureClip1.ClipHeight = 50;
           axPictureClip1.ClipWidth = 50;
           pictureBox5.Image = axPictureClip1.Clip;//取出一小块
//抓屏截图
private void button15_Click(object sender, EventArgs e)
           Image objImage = new Bitmap(400, 300);
           Graphics g = Graphics.FromImage(objImage);
           g.CopyFromScreen(new Point(Cursor.Position.X - 150, Cursor.Position.Y - 25),new Point(0, 0), new Size(400, 300));
           IntPtr dc1 = g.GetHdc();
           g.ReleaseHdc(dc1);
           this.pictureBox1.Image = objImage;
           objImage.Save("e:\\test.jpg");
该文章在 2021/1/20 11:12:02 编辑过
