C#在WinForm下使用HttpWebRequest上传文件并显示进度
2017年3月21日 23:39 本文热度 7586
/// <summary>
/// 将本地文件上传到指定的服务器(HttpWebRequest方法)
/// </summary>
/// <param name="address">文件上传到的服务器</param>
/// <param name="fileNamePath">要上传的本地文件(全路径)</param>
/// <param name="saveName">文件上传后的名称</param>
/// <param name="progressBar">上传进度条</param>
/// <returns>成功返回1,失败返回0</returns>
private int Upload_Request(string address, string fileNamePath, string saveName, ProgressBar progressBar)
    int returnValue = 0;
    // 要上传的文件
    FileStream fs = new FileStream(fileNamePath, FileMode.Open, FileAccess.Read);
    BinaryReader r = new BinaryReader(fs);
    //时间戳
    string strBoundary = "----------" + DateTime.Now.Ticks.ToString("x");
    byte[] boundaryBytes = Encoding.ASCII.GetBytes("\r\n--" + strBoundary + "\r\n");
    //请求头部信息
    StringBuilder sb = new StringBuilder();
    sb.Append("--");
    sb.Append(strBoundary);
    sb.Append("\r\n");
    sb.Append("Content-Disposition: form-data; name="");
    sb.Append("file");
    sb.Append(""; filename="");
    sb.Append(saveName);
    sb.Append(""");
    sb.Append("\r\n");
    sb.Append("Content-Type: ");
    sb.Append("application/octet-stream");
    sb.Append("\r\n");
    sb.Append("\r\n");
    string strPostHeader = sb.ToString();
    byte[] postHeaderBytes = Encoding.UTF8.GetBytes(strPostHeader);
    // 根据uri创建HttpWebRequest对象
    HttpWebRequest httpReq = (HttpWebRequest)WebRequest.Create(new Uri(address));
    httpReq.Method = "POST";
    //对发送的数据不使用缓存
    httpReq.AllowWriteStreamBuffering = false;
    //设置获得响应的超时时间(默认300秒)
    httpReq.Timeout = 300000;
    httpReq.ContentType = "multipart/form-data; boundary=" + strBoundary;
    long length = fs.Length + postHeaderBytes.Length + boundaryBytes.Length;
    long fileLength = fs.Length;
    httpReq.ContentLength = length;
    try
        progressBar.Maximum = int.MaxValue;
        progressBar.Minimum = 0;
        progressBar.Value = 0;
        //每次上传4k
        int bufferLength = 4096;
        byte[] buffer = new byte[bufferLength];
        //已上传的字节数
        long offset = 0;
        //开始上传时间
        DateTime startTime = DateTime.Now;
        int size = r.Read(buffer, 0, bufferLength);
        Stream postStream = httpReq.GetRequestStream();
        //发送请求头部消息
        postStream.Write(postHeaderBytes, 0, postHeaderBytes.Length);
        while (size > 0)
            postStream.Write(buffer, 0, size);
            offset += size;
            progressBar.Value = (int)(offset * (int.MaxValue / length));
            TimeSpan span = DateTime.Now - startTime;
            double second = span.TotalSeconds;
            lblTime.Text = "已用时:" + second.ToString("F2") + "秒";
            if (second > 0.001)
                lblSpeed.Text = " 平均速度:" + (offset / 1024 / second).ToString("0.00") + "KB/秒";
                lblSpeed.Text = " 正在连接…";
            lblState.Text = "已上传:" + (offset * 100.0 / length).ToString("F2") + "%";
            lblSize.Text = (offset / 1048576.0).ToString("F2") + "M/" + (fileLength / 1048576.0).ToString("F2") + "M";
            Application.DoEvents();
        //添加尾部的时间戳
        postStream.Write(boundaryBytes, 0, boundaryBytes.Length);
        postStream.Close();
        //获取服务器端的响应
        WebResponse webRespon = httpReq.GetResponse();
        Stream s = webRespon.GetResponseStream();
        StreamReader sr = new StreamReader(s);
        //读取服务器端返回的消息
        String sReturnString = sr.ReadLine();
        s.Close();
        sr.Close();
        if (sReturnString == "Success")
            returnValue = 1;
        else if (sReturnString == "Error")
            returnValue = 0;
    catch
        returnValue = 0;
    finally
        fs.Close();
        r.Close();
    return returnValue;
参数说明如下:
address:接收文件的URL地址,如:http://localhost/UploadFile/Save.aspx
fileNamePath:要上传的本地文件,如:D:\test.rar
saveName:文件上传到服务器后的名称,如:200901011234.rar
progressBar:显示文件上传进度的进度条。
接收文件的WebForm添加一个Save.aspx页面,Load方法如下:
protected void Page_Load(object sender, EventArgs e)
    if (Request.Files.Count > 0)
        try
            HttpPostedFile file = Request.Files[0];
            string filePath = this.MapPath("UploadDocument") + "\" + file.FileName;
            file.SaveAs(filePath);
            Response.Write("Success\r\n");
        catch
            Response.Write("Error\r\n");
同时需要配置WebConfig文件的httpRuntime 如下:
<httpRuntime maxRequestLength="102400" executionTimeout="300"/>
不能的话最大只能上传4M了。要是想上传更大的文件,maxRequestLength,executionTimeout设置大些,同时WinForm下的代码行
//设置获得响应的超时时间(300秒)
也要修改,另外别忘了看看IIS的连接超时是否设置为足够大。
该文章在 2017/3/21 23:39:11 编辑过
